Move command issue
Move command issue
Message 1 of 10
Move command issue
I am having a strange issue that I cannot duplicate.  Sometimes when I move an object, it seems to go into the tracking command and will not let me drop the object without placing it in 2 or more places before dropping.  I am not using the tracking command.  It does not matter if I have ortho turned on or off.  Please excuse me if this has already been asked, but I searched and could not find anything like this issue.
Dave
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
How does MOVE command require you to place it in 2 or more places?
Message 3 of 10
The following is a rundown of the process that I go through after entering the MOVE command
1. select object to be moved
2. select base point
3. click to drop object (not on a specified point, but in "space").  This is where things go awry as the object will not be placed.
4. Autocad asks for another point.  Select another point (in "space").  Object still not placed.
This happens 2 to 5 times before the object is actually placed, but not all the time.  Sometimes it will work for a few days, but then it will happen almost all the time for a day or so.
dave
Message 4 of 10
pendean
Community Legend
Community Legend
Open/start a new blank file in AutoCAD. Draw something.
Can you replicate the move issue with this drawn object? probably not right? Copy/paste the previous object from the problem file into this empty one, does the object look weird? Does it suddenly fail to move the same way?
Message 5 of 10
jayhar
Restart AutoCAD
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 6 of 10
ChrisPreece
Hi @Anonymous,
I see that you're posting for the first time. Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD LT forum.
I'm just checking in to see if you need more help with this. Did the suggestions that @pendean and @jayhar provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Chris Preece
Technical Support Specialist
Message 7 of 10
Neither of these solutions has fixed my problem. I will mention that in
the thread
Message 8 of 10
pendean
Community Legend
Community Legend
Show us the problem in action: install SCREENCAST and record yourself in a brand new file with this problem https://knowledge.autodesk.com/community/screencast
Message 9 of 10
I will try to capture this when it happens.  Like I mentioned before, it may be a few days before it happens again.
Thank you
dave
Message 10 of 10
pendean
Community Legend
Community Legend
So it is a random occurrence? You made it sound like it happens all the time in every file.
There is no fix for random: next time it happens restart AutoCAD or your PC and it should go away as noted in message #5
