Missing tab options- annotation
2WVZG3
2WVZG3
I used to have options to quick change my settings for dimensions, leaders, and tables in the annotation dropdown menu, but for some reason they have disappeared? I have run a repair cycle, but they are still missing.
Try a restart of your machine, sometimes your display gets a hic-up.  If it continues you can try to turn off your hardware accelerator off.
2WVZG3
Thanks for the suggestion, unfortunately neither has fixed the problem. Any other possibilities before I do a full reinstall of autocad?
steven-g
Are those drop downs still available on the 'annotations' tab of the ribbon?
pendean
Community Legend
Community Legend
Do you have the 2020.1.3 update installed yet? ABOUT command will confirm which 2020 version you are running, you can get the update from your Autodesk Accounts page here https://manage.autodesk.com/
