Announcements
Macro Syntax Help For LAYMRG
I have been struggling with a -LAYMRG macro. Here's what I need it to do:
  1. Start the -LAYMRG command
  2. Select all source objects with mouse (SELECT)
  3. On user completing the selection and pressing enter, merge those layers selected to a specific layer specified in the macro (XX - Layout).
Here's what I have so far: ^C^C-laymrg;select;n;"XX - Layout"
I have tried many different syntax and special characters but at the stage when it asks to select the destination layer to merge to, I can't make it select "Name" without manually typing N. I want it to do that immediately after selection has completed. Why won't the macro progress past SELECT without my input?
Many thanks.
cadffm
-LAYMRG is not designd for this,
you need a more complex macro to do this, or better you need 2 macros to do this.
Simpler is: LAYCUR
Set the target layer as current layer first.
Sebastian
cadffm
Oh, i read it again and i see you don't understand where the problem is!
Please type in, by hand:
Command: -LAYMRG
following by: SELECT
Read the commandline now [F2]
This is the time where your macro brokes, not much later when you trying to enter N
Sebastian
Yeah I thought that was the issue. Using SELECT isn't proper at that point.
Thanks for the LAYCUR advice. I'm very close now.
^C^C-LAYER;S;"SC - Layout";^CLAYCUR;
The above does almost exactly what I want. I would prefer that an object selection would select everything on that layer, not just the object. I guess this is what you meant when you suggested 2 macros.
What do you think?
cadffm
You can go multiple ways in with "just LT" it is really to to make a perfect solution
More perfect -> often more complicated
Example, which needs to CANCEL if you like to stop the command.
*^C^C^C_.-LAYER;_new;"XX - Layout";;_.-LAYMRG;\;_name;XX - Layout;_yes
Sebastian
That's perfect. I see what you did there. Syntax like "_.-LAYMRG" is exactly what I needed to know.
Thank you!
