Macro command for plot in model.
NASHARUDINC8MF7
Message 1 of 16
NASHARUDINC8MF7
Hi.
I want to make macro command to save by 1 click.
After we press Ctrl+P, the plot model will popup, and we need to click the windows option to make a selection an area we want to plot.
I want to bypass the 1 time click on the window < option. Is it able to do?
If yes, could please share the command.
Replies (15)
Message 2 of 16
pendean
Community Legend
Community Legend
What are your other plot parameters please?
BTW, did you know you could master creating your own macro yourself with just a little time: practice using the -PLOT command (there is a dash i the name that you can type), work out all the details you want and if you still need it we can help you finish writing that macro.
Message 3 of 16
NASHARUDINC8MF7
i don't use layout for plot. Since there are alot of drawing revision in one dwg file, i just use model so i can choose which revision i want to plot.
plot parameters means its a fix position to plot right, i don't want a fix parameters.
the command i use right now (^C^C_PLOT;Y;;Window;Y;), its not working, i still need to click the windows < icon to before i select area to plot. i just want to skip the 1 time click on windows < icon .
If possible, its great if you can share the macro.
Message 4 of 16
cadffm
create it by yourself. AutoCAD will wait for one-user-input, if you are add a backslash to your macro!
Figure out the macro up to the point -plot ask for the first coordinate, then add \ for the first, and if -plot ask for the second windows coordinate, add another \
and add the rest of the macro..
It's easy, but step by step.
Sebastian
Message 5 of 16
paullimapa
you're missing lots of information in your plot macro even before getting to the Window option:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-print-a-lay...
The link provides an example that plots to area of Extents but in a Layout and Not Model:
But notice the way to see how to proceed with editing the macro as shown in the same link:
I would also suggest while in Model tab set FILEDIA to 0 and CMDDIA to 0.
Then enter -PLOT command and go through the command line prompts and set your macro that way.
Then afterwards remember to set FILEDIA back to 1 and CMDDIA back to 1.
Paul Li
IT Specialist
@The Office
Message 6 of 16
NASHARUDINC8MF7
I want to bypass the click on that windows icon.
When i use this command (original was Extents, changed to window)
^C^C_zoom;e;-PLOT;Y;;DWG to PDF.pc3;ISO A1 (841.00 x 594.00 MM);Millimeters;Landscape;no;window;fit;Center;Yes;.;Yes;;Yes;Yes;;No;Yes
it did stop on window, however i need to continue choose the things after that (fit,center etc) .
how can i break the code until window, so i don't need to choose the next things?
Message 7 of 16
paullimapa
@cadffm already provided you with the answer to your question.
For the macro to pause so that you can select the first window coordinate add a \
Then for it to pause to select the second window coordinate add a \ again
Try it like this:
^C^C_zoom;e;-PLOT;Y;;DWG to PDF.pc3;ISO A1 (841.00 x 594.00 MM);Millimeters;Landscape;no;window;\\fit;Center;Yes;.;Yes;;Yes;Yes;;No;Yes
You can read more about using the back slash as a pause for user input here:
Command macro cannot select multiple objects in AutoCAD LT (autodesk.com)
Paul Li
IT Specialist
@The Office
Message 8 of 16
NASHARUDINC8MF7
Yes this one is working like a charm.
Thanks alot.
Just need to change a bit about the code, i change like this. Then i get what i want.
 ^C^C_zoom;e;-PLOT;Y;;DWG to PDF.pc3;ISO A1 (841.00 x 594.00 MM);Millimeters;Landscape;no;window;\\fit;Center;Yes;.;Yes;;Yes;Yes;;Yes
Message 9 of 16
paullimapa
very good...looks like you've got down the plot sequence for the Model tab which is slightly different than the Layout tab given in the previous example...cheers!!!
Paul Li
IT Specialist
@The Office
Message 10 of 16
NASHARUDINC8MF7
Im sorry, one more things, everything works fine, accept the pdf file is named as Yes.Pdf
How can i save it as original filename of any dwg file?
Message 11 of 16
paullimapa
Try this change based on the sequence of prompts I'm seeing with -PLOT:
^C^C_zoom;e;-PLOT;Y;;DWG to PDF.pc3;ISO A1 (841.00 x 594.00 MM);Millimeters;Landscape;no;window;\\fit;Center;Yes;.;Yes;A;;Yes;Yes;
Paul Li
IT Specialist
@The Office
Message 12 of 16
NASHARUDINC8MF7
I don't really know what the problem just now, a bug i guess.
I'm still using the same command as above. After i restart autocad, it's all working fine.
Sorry for that.
Message 13 of 16
NASHARUDINC8MF7
Got another things coming up, can i use this same macro and i want to choose the pdf location.
For now, it will save on the same folder at the dwg file itself.
Message 14 of 16
paullimapa
try this:
^C^C_zoom;e;-PLOT;Y;;DWG to PDF.pc3;ISO A1 (841.00 x 594.00 MM);Millimeters;Landscape;no;window;\\fit;Center;Yes;.;Yes;A;~;Yes;Yes;
Paul Li
IT Specialist
@The Office
Message 15 of 16
NASHARUDINC8MF7
Wow its working.
Thanks again sir. You are so kind.
Message 16 of 16
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
