Since upgrading to 2025 last week, I am having constant issues with my screen suddenly turning a colour, almost like it develops a solid hatch. If I scroll out, or in, it will go away, sometimes for a while, sometimes it reappears when I scroll in again. It's starting to drive me nuts..... This is what my screen looks like when there is an issue. There is a drawing in there somewhere.
This is what my screen looks like when I zoom out.
But is also happens in an unactivated viewport when I am in paper space.
Solved by paullimapa. Go to Solution.
First make sure you’ve downloaded and installed 2025.1.1 LT update
If still no joy then at command prompt enter Gfxdx12 and set this to 0 and restart LT. If still no joy enter command GraphicsConfig and change 2D Display Settings to another option
TY, I did the update and then changed the gfxdx12 setting. Will see what happens today. So far all good so maybe I don't have to change the display settings......from what I can remember that seemed to cause me problems on previous versions.
Glad that’s working out for you…cheers!!!
