An employee just said that she twice this morning had her drawing jump back to a few minutes prior when her autosave saves. Not too big a deal, but she did lose a couple minutes of work each time. Any ideas? In the meantime I had her turn autosave off, but that doesn't seem like a solution, just a band-aid.
HI @clymanPM2ES,
A few questions for you:
Post back with any updates.
Thanks.
Thanks for the reply.
Files are saved to a server. I haven't confirmed that the file save paths are correct, but I did do the initial setup and they were correct at the time. I also don't know if its happening on multiple drawings, but it is only one person. The person having the problem was working on one file and had this happen twice in 10 minutes so I had her turn off the auto save until I could find a solution.
If it's just happening to one seat. Then something must have changed for her seat on some sort of level in AutoCAD or her system.
Let's see if we can narrow it down if you could have her test that file by saving locally and to see if the issue reoccurs.
If she has the time to test a few other drawings that would help as well.
Let me know. I'll try to do some additional testing on my side to see if I can reproduce the same problem.
Hi @clymanPM2ES,
Just checking back on this thread, were you able to find the root of the issue?
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
