Link between block reference and viewport
I want to link the "annotation scale" on the viewport; to my info block to automatically update, when I zoom in and out. Update the field automatically.
Please point me in the right direction, I'm quite noob with autocad.
Im running Autodesk autocad LT 2019, just in case this might be of importance.
pendean
Community Legend
Community Legend
FIELD command: you want to select OBJECT under field name,them select the viewport, ten the CUSTOM SCALE property., then format. The place it where you want.
Fields are updated when you use REGEN or REGENALL command after you do whatever with your viewport.
steven-g
Do you have attributes in the title block? If not you will need to add an Attribute. How you proceed depends on that so let us know.
