On opening the DWG, all lineweights display as cartoonishly bold. Toggling lineweight off does remove "boldness", but only until you pan/zoom or enter a command, at which point the lineweights display as before... *** though the LWDISPLAY variable remains at 0 ***.
Also, when zooming, the lineweights scale, as if all of the geometry was polylines of non-zero width.
This glitch is only exhibiting in one drawing file (so far), but across various devices and versions of LT. Back-saving doesn't remedy things, and audit shows no errors. To be clear, this is only a display error, i.e. the file prints as intended.
Any thoughts/advice much appreciated.
Link copied
