Just started work for this company and when I started using autocad LT the drawings didn't line up straight. So I turned on ortho and the drawing still wasn't straight. I would also make straight polylines then I would offset and those lines wouldn't be straight.
Please help!
Thank you.
Solved by JamesPowell7164. Go to Solution.
Solved by pendean. Go to Solution.
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Dean
I remember that this happened to me and you helped me. It was something to do with snap and ortho? Vertical and horizontal lines were slightly off, i.e. not 90 degrees?
EDIT:
With POLAR set to 15, horizontal lines are horizontal and vertical lines are vertical. no deviations.
Same results with ORTHO on.
The moment I turn on running OSNAPs and get close to any of your drawn objects I can see the cursor pull towards them: I suspect this is why you see deviations, you may be using other points to click on thus skewing the lines.
Get in the habit of toggle osnaps off (F3) and only turn them on (F3) when you need them and only when you are zoomed in to ensure you are clicking on the object snap you want to use.
