AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Lines are non coplanar ??
7 REPLIES 7
Message 1 of 8
6815 Views, 7 Replies
I want to "Fillet" a round angle. If I set the radius and then click the 2 lines then Autocad comes with the message: "Lines are non Coplanar" This problem just started in a drawing i was working in ( 50% were already done by Fillet perfectly ) , I draw only 2D. What am I doing wrong?
7 REPLIES 7
Message 2 of 8
h_s_walker
That simply means the lines are not on the same Z axis.
There is somewhere in here a set of commands which will set all your objects back to 0 on the Z axis.
To do it with these two lines, select both of them. Right click and choose properties.
If they are polylines. Look for the word "ELEVATION" and change that to 0
If they are lines look for the words "START Z" and "END Z" change both of those to 0
You will now be able to fillet your lines
Howard Walker
Left Handed and Proud
Message 3 of 8
in reply to: h_s_walker
Thanks !
This works.
I started all over again because i had this problem with al the lines 😞
Message 4 of 8
Is it there a limited number of items to be selected? I selected about 1500 lines and I don't get elevation points x,y,z in the properties table. Few lines are ok.
Message 5 of 8
h_s_walker
At the command line type OPTIONS
Choose the SELECTION TAB
Look for the OBJECT LIMIT FOR PROPERTIES PALETTE and OBJECT LIMIT FOR DISPLAY OF GRIPS. Make the numbers bigger.
Howard Walker
Message 6 of 8
Thanks for answering but the maximum allowed is still too small. I had it on 25000 and maximum is 32000.
Message 7 of 8
pendean
Then select fewer lines perhaps? There is a built-in maximum limit you cannot change.
Message 8 of 8
in reply to: pendean
That's right. So I have to do. I was not sure if it is a limit or my program installation is fault. Thanks.
Technology Administrators
