Line transparency
Line transparency
rhbelter
Line transparency
rhbelter
Ahoy, All,
I am having a problem with faded-out lines on my drawings.  The layer control shows '0' value but the lines are still faint.  Any solution?
Enjoy    /s/      Bob
Accepted solutions (3)
cadffm
is it a LOCKed Layer?
LAYLOCKFADECTL
Sebastian
rhbelter
Ahoy Betreff, no, not a locked layer.
Thanks /s/ Bob
cadffm
Ahoy Reply , share your .dwg (or a copy, delete all except one of these lines).
Sebastian
pendean
Community Legend
Community Legend
Are you running LT2024-2024-2025? Turn off GFXDX12 variable then restart your program, that should fix it.
If not, start GRAPHICSCONFIG command then turn off hardware acceleration: if that fixed it, your AutoCAD/LT version and your video card or its current driver do not get along, time to hunt for a new (or older) driver for it if you want to take the time to do so (just keep in mind you may never find such a driver).
HTH
rhbelter
Ahoy, pendean,
THANK YOU THANK YOU THANK YOU.
Your solution fixed my problem.
Enjoy     /s/       Bob
