Line problems
Line problems
Line problems
I have installed recently LT2017 and have a problem with lines. It´s only "hidden" line not continious line, can´t find the way to change it.
Can it be a problem with my new computers graphic card?
The  graphic is Intel Iris Graphics 540.
What´s strange is that all new and all old drawings are this hidden line type, but when I make a paperdrawing it´s ok whit continius lines.
pendean
Community Legend
Community Legend
Turn off LINESMOOTHING and LINEFADING variables (type them at the commandline) and see if that helps.
Emmsleys
Have you tested AutoCAD LT 2017 on a different system? or logged in as a different user on your system to see if the same behavior happens in that environment?
You could try resetting your settings to default, but save your settings as needed.
Sarah Emmsley
Technical Support Specialist
Emmsleys
post back with any new findings or updates when convenient.
Sarah Emmsley
