Layouts with specific layers - LT2021
fkoHMT34
fkoHMT34
Hi forum
I am about to make a drawing with elements placed above each other or very near each other.
If I group the elements on different layers, is it then possible to make layouts where some layers are turned off, and other layers are turned on?
For example one layout with guideways alone for electrical wires, and another layer alone for electrical components.
Or do I have to make different drawings to each type of elements?
Accepted solutions (4)
cadffm
while in Layout:
doubleclick inside viewport
or type in .pspace
or CTRL+R
or click PAPER in statusbar
Open your LAYER palette,
column VP LAYER is what you need.
See also command VPLAYER.
VP LAYER is a viewport or and paperspace(for paperspace objects) property.
Read more about [F1]
Sebastian
steven-g
To add to the comment from @cadffm there are many settings in the Layer manager that can be applied to just individual viewports, these all begin with VP, things like 'VP Color' and 'VP Transparency'.
cadffm
I have to edit my post, there is a little mistake:
or CTRL+R
is not for jumping inside a viewport, it#s just for toggling between multiple viewports.
sorry
Sebastian
fkoHMT34
Thanks a lot
I have now a solution.
But I am not absolute shure if there is at better way to achieve it.
In [Layer Properties] i cheked [New VP Freeze] for the layers which not schould appear in the current Layout.
Subsequently I created a new layer and everything is as desired.
I have attach the dwg file and screenshot of Layer Properties Manager.
Sincerely, Flemming
cadffm
Please read [F1], New VP Freeze is only for new viewports.
If this property is set, in new viewports this layer will VP Freeze as default.
For the current Layout (Layout[Paper])
- for Paperspace placed objects
or
inside a viewport (Layout[Model])
for Modelspace placed objects thru a viewport
We talk about column VP LAYER
[F1]
Sebastian
fkoHMT34
Ok and many thanks
Now I have it
I am grateful for your guidance
Sincerely, Fleming
