Layer Properties Search Function
JerryKearney
Observer Observer
JerryKearney
Observer
Observer
Hi all, We are using Autocad LT 2024 on windows 11. I use the layer properties box when selecting line types, however the search bar searches the British Standard abbreviated text in the name (left hand column) as opposed to the generic name in the description (right hand column). Does anyone know if you can alter the set up of the search function to search the description column?
Thanks. JK
pendean
Community Legend
Community Legend
That search box is still limited to layer names only https://help.autodesk.com/view/ACDLT/2024/ENU/index.html?guid=GUID-B297EBD9-D68C-47E1-87CE-1B3798496....
You could consider using LAYER FILTERS more to help sort your long list of layers into smaller manageable lists https://help.autodesk.com/view/ACDLT/2024/ENU/index.html?guid=GUID-026A95F8-4EBB-48BD-8C8C-15B381DB4...
JerryKearney
Observer
Observer
Thanks Pendean, I thought that might be the answer.
