Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
keyboard shortcuts autocad lt
3 REPLIES 3
romee86PJA
326 Views, 3 Replies
hello,
I'm trying to find a list of keyboard shortcuts for autocad lt that are fixed. in the cui i can't see the diffence between the ones i can and cannot change. for example, F1 is always ''help'' for the 2024 lt version of autocad, but for autocad 2024 you can change it to something else. does anyone know with shortcuts i can't change in autocad 2024 LT?
thank you in advance 🙂
Tags (1)
3 REPLIES 3
cadffm
in reply to: romee86PJA
>"I'm trying to find a list of keyboard shortcuts for autocad lt that are fixed"
Standard WINDOWS shortcuts are not edible by the usual way you can edit AutoCAD(LT) shortcuts.
Also, there a some specials you can't change, like HOLD SHIFT while trim or fillet and it will change to expand and temporary radius0
>>" in the cui i can't see the diffence between the ones i can and cannot change"
Because you can't see the ones you can't edit.
>"example, F1 is always ''help'' for the 2024 lt version of autocad, but for autocad 2024"
In all versions and all "windows standard designed syntax" Programs, [F1] will start Help
>"you can change it to something else"
No. There is no difference. You can do it in ACAD the same way as in LT, you can overwrite the F1 key with an AutoCAD shortcut.
>". does anyone know with shortcuts i can't change in autocad 2024 LT?"
May I ask what this list would be good for?
General good link for who will learn about keyboard shortcuts and more  / Scroll down
https://www.autodesk.com/shortcuts/autocad
Sebastian
jarek_zal
If you want to change keyboard shortcuts for functions, go to the Manage tab and from the Customization panel, select Edit Aliasses.
Then a window will open in notepad or similar editor (acad.pgp) where you will have a list of all shortcuts.
If you want to change it to your own, copy it to the bottom and change the shortcut to your own.
Jarek
jarek_zal
in reply to: jarek_zal
I forgot, they still need to be reloaded after changing and saving the acad.pgp file.
To do this, enter REINIT and select "Select PGP file" and then ok. Or restart Autocad 😉
Technology Administrators
