>"I'm trying to find a list of keyboard shortcuts for autocad lt that are fixed"
Standard WINDOWS shortcuts are not edible by the usual way you can edit AutoCAD(LT) shortcuts.
Also, there a some specials you can't change, like HOLD SHIFT while trim or fillet and it will change to expand and temporary radius0
>>" in the cui i can't see the diffence between the ones i can and cannot change"
Because you can't see the ones you can't edit.
>"example, F1 is always ''help'' for the 2024 lt version of autocad, but for autocad 2024"
In all versions and all "windows standard designed syntax" Programs, [F1] will start Help
>"you can change it to something else"
No. There is no difference. You can do it in ACAD the same way as in LT, you can overwrite the F1 key with an AutoCAD shortcut.
>". does anyone know with shortcuts i can't change in autocad 2024 LT?"
May I ask what this list would be good for?
General good link for who will learn about keyboard shortcuts and more / Scroll down
https://www.autodesk.com/shortcuts/autocad
