It there a way to automate creating new viewports to have the fields automatically show?
sdrisk8262
sdrisk8262
I was wondering if there was a way that when I create a new viewports the scale and lock status would appear.  Without having to start mtext adding the fields, setting the layer and colors to use?  I have never created or used macros or scripts in Autocad LT.  I have only created it once then just copy pasted where ever I needed.  I have seen videos in the past where someone copied the command lines they wanted to repeat in a macros.  I have forgotten where and what they did to accomplish this.  Thanks
pendean
Community Legend
Community Legend
@sdrisk8262 What does "yes" mean in your screenshot of your viewport please?
How do you create viewports now to a scale:
1) do you use the NEW sub-option in MVIEW command to create it to scale to your objects?
2) or randomly create a generic viewport then go inside it to pan and zoom, then back out to size it up?
3) or you create a name view in modelspace set to a CANNOSCALE setting then MVIEW's sub-option VIEW?
4) Do you use the system variable ANNOSCALEZOOM at all?
sdrisk8262
"scale and lock status"  mtext fields
random generic in paper space
I click the text in the bar not exactly sure what commands it uses:
viewport > 1
Size it, pan zoom to the area. Then I manual set the scale I want.
sdrisk8262
I use -vports on the layout tabs.
I am open if there is a better way.
paullimapa
if you're running LT 2024 which supports lisp then post your question in the lisp customization forum:
Visual LISP, AutoLISP, General Customization Forum Autodesk
Paul Li
IT Specialist
@The Office
