Issue when using polar array
sean.waltman
sean.waltman
Good morning,
I'm trying to array a number of bolt holes. When specifying the "fill" angle in polar array, I need it fill between an angle of 82.36. The software is defaulting back to 82 degrees automatically. Normally I could get away with this but we're looking to manufacture a high tolerance part, which will not work in this instance.
Any suggestions on why I cannot fine tune this to the angle needed in polar array?
Thanks!
cadffm
set up here, Command: _UNITS
(AUPREC)
MY-standard setup is LUPREC and AUPREC = 8
because: Why not? This setting is only for the gui, it doesn't change the drawing,
but it helps to see the real values and why should i want to see the wrong (rounded) values?
After set auprec to 2 or 8, try it again
Sebastian
