I'm attempting to re-install AutoCAD LT 2007 on a HP Media Center PC running Windows XP SP3. The machine locked up earlier and I was forced to do a complete HP restore, which left me with Windows SP2. After upgrading back to SP3, I tried to open ACLT from the desktop and got the message that the "Shortcut works only with programs that are installed" So I pulled out the disk and when I selected the default C Drive as the location, the installer responded that the AC LT was already installed there. Sure enough, when I checked the C Drive, there was a full AutoCAD LT 2007 folder already there.
I thought to uninstall AC LT in order to install a fresh copy, but of course, AC LT did no appear in the Control Panel.
I manually moved the AC LT folder from the C Drive to the Recycle Bin, but when I ran the installer again, midway through up popped the Internal Error 2337 message, When I clicked OK, the installer "rewound" and backed out of the installation and quit.
The Autodesk KB returns no answer to the query "Internal Error 2337."
Any suggestions?
