Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Intel C States \ Speedstep Issue AutoCad LT 19\20
Hi All,
Just wanted to share an issue I just ran into.
I had a user call me with a performance issue since I patched his install of 19, to the latest update. Turns out the processor was not throttling up while he was using AutoCAD LT, and the issue only occurred while AutoCAD LT was running.
I upgraded his install to 2020 and the issue persisted. Strangely did not seem to affect 19 pre-update. The whole system was just bogged down, even affected mouse movement!
The fix was to disable Intel C States & Speedstep in the BIOS, this fixed the issue. Albeit at the cost of battery life. Now this may be hardware specific, so the computer was a Dell Latitude 5580 laptop FYI.
Just wanted to throw this out there for anyone that might need it.
Cheers.
Thomas_Stuehle
Hello @Anonymous,
thanks for your topic and that you posted the solution with this level of detail.
Please note that I will also document the information in our Autodesk Knowledge Network. I would like to mark your topic also as your solution to show further appreciation and to make it also more findable. Please reply to my posting and I will mark your message as a solution.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
Hi Thomas,
Thanks for the reply.
Regards
Paul.
