Increasing File Size
we have three old Autocad LT 2014 licenses.
For our work we actually not need to upgrade.
Unfortunately we have the issue described here: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
We know it's not possibile to request support directly from Autodesk (we don't have active subscriptions).
Since the resolutions proposed in the KB are not working for us, do you think there are some others possible solutions, or we have to change our Autocad LT with newer version?
Thank's
cadffm
" do you think there are some others possible solutions,"
YES.
The solution depends on the problem, the problem is in the file and we do not know the file.
How big is the file?
how big should the file be in your opinion?
when does the file increase (by how much)?
Where is the DWG, then we can search your problem.
Sebastian
pendean
Community Legend
Community Legend
Fix your file(s), there are a dozen or so methods, no single one is perfect, start here https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
