Import PDF to DWG
donnadupree
Import PDF to DWG
donnadupree
Hi all!
I am working with AutoCad Lt 2024 (and new at it) and am trying to import a PDF image into a DWG - I see it can be done but all that is happening for me is an image imports that is exactly the same as the PDF image.  For example, if I import a graph or drawing (such as from a patent), it merely imports identically to the PDF.  Any insight would be greatly appreciated!
Thank you!
Best,
Donna
Replies (11)
pendean
Community Legend
Community Legend
AutoCAD/LT can only convert what are called "vector" PDF files using PDFIMPORT command.
If you only get images with that command, you have a "raster" PDF, the result of a scan or a pdf from a pdf from a pdf: for converting that type, you will most likely need to purchase a 3rd party software (called RASTER TO VECTOR) if just tracing over the image in LT will take too long for you/your budget https://www.google.com/search?q=raster+to+vector+software
paullimapa
One quick test to see if you're doing everything correctly is to:
1. Open a drawing with objects drawn
2. Plot to pdf using DWG to PDF.pc3
3. Open a new drawing
4. Run PDFImport command selecting the pdf you just created
If you see vector objects imported then there's nothing wrong with what you've been doing.
The issue has to do with the PDF you're trying to import which may only contain raster information with no vectors to import.
Paul Li
IT Specialist
@The Office
h_s_walker
If as Dean says it's a Raster PDF I would convert it to a JPEG. I only have LT2016 here, but having too many PDFS in a drawing slows the work down drastically and sometimes it won't even publish all the tabs in the drawing.
Howard Walker
Left Handed and Proud
donnadupree
Thank you for your prompt response - I've been on many forums and receive no help at all!
I think you are right. I made a simple Word drawing - square, triangle, star - and saved it as a PDF and it came over perfectly as a dwf in AutoCad. Can you help me understand what needs to be done for transferring raster information? I tried with these images (Inkscape) and received a bit of a jumble (the graph being the worse, which obviously needs to be accurate), but maybe that is the best I can hope for? Or do I have to trace particularly complicated images (e.g., drilling rigs)? Thank you so much!
[cid:7869d192-549a-4734-8e2b-b11429b24971][cid:daf9e825-a1d4-4627-b3b4-a78c3672a3d7]
[cid:38194911-7410-4a27-897e-043700e7c995][cid:2fd75f9d-f720-4ac9-8b5a-c69571f50517]
Best,
Donna
donnadupree
Thanks! Can I import a JPEG? I appreciate your support; I am clearly new to this!
pendean
Community Legend
Community Legend
AutoCAD does not convert Raster Images like JPEG/JPG: explore IMAGEATTACH command in the program's HELP for what can be done instead.
donnadupree
WHOA!!!!!!!!!!!! This is amazing! THANK YOU!!
cadffm
okay,
so you also don't know about PDFATTACH ?
Or XREF -> PDF
Sebastian
donnadupree
I do not...
pendean
Community Legend
Community Legend
@donnadupree wrote:
I do not...
Might I suggest this page from HELP inside AutoCAD/LT
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-5F10E306-BC6C-49C4-B9C4-5F05EEC72146
HTH
donnadupree
Many thanks!
