Import pdf then change colors
I have Imported a pdf into my workspace, since copy and pasted the object multiple times.  I didn't think much about the object being draw with white lines since I am using the dark background for drawing.  However, when I go to print the drawing (convert drawing to .pdf), said objects still remain white on the white background of the .pdf.
I have Selected all the object and tried changing the Properties color to black, but it does not seem to transition the objects to black, they remain white. Any idea what I need to do?  The steps involved?
pendean
Community Legend
Community Legend
Post a potion of that DWG file with the lines in question, let's all have a look.
Attached is one of the object that I am trying to change.
File didn't attach to my previous reply.  See attached now.
pendean
Community Legend
Community Legend
It's a block: so you need to change the properties of the objects inside the block to what you want like BYBLOCK or BYLAYER (you can use REFEDIT or BEDIT commands), then change the actual color of the block afterwards using Properties command.
SETBYLAYER command may help do what you wnt as well, explore how to use it in HELP and test it thoroughly first.
See your file back.
Emmsleys
@Anonymous,
If you still have questions after trying the suggestions posted, reply back in the thread. If any of the post's answered your question select Accept as Solution.
Sarah Emmsley
Technical Support Specialist
Emmsleys
Thanks.
Sarah Emmsley
