I need macros for the Associative hatch
Message 1 of 18
I need macros for the Associative hatch. I use such kind of macros:
^C^C_hatch ansi31 200 0
^C^C_hatch;ansi31;200;0
It works but produces NONassociative hatches. What is wrong ?
Replies (17)
Message 2 of 18
steven-g
Run the _hatch command and read the prompts.
The first prompt is expecting a pick point or it will accept a keyword (not a hatch name) to use a hatch name you first need to tell the macro to use the 'properties' option and from that prompt you can enter a pattern name.
If annotative isn't already the default then that is also an option given to use annotative from the command line version.
The most important thing to watch when creating macros is run the commands first from your keyboard and see what prompts are available, then use that sequence to write your macro.
Message 3 of 18
Unfortunatelly you are not correct. Try youself before the answer! AutoCad goes different logic in command line and Macros. In case of Macros it asks hatch type first!
Message 4 of 18
pendean
Community Legend
Community Legend
HPASSOC variable needs to be on, look up usage in HELP.
While you are in HELP, look up all the other hatch variables (almost all start with HP), you'll be amazed at how much control you can get for macros.
HTH
Message 5 of 18
HPASSOC is ON. Nothing new unfortunatelly.
Any text I type beside the hatch command breaks the accociation to boundary. Probably this is the software bug nobody noticed yet.
Message 6 of 18
If who has time it's even faster to try yourself than type wrong answers.
Offered macro ---  ^C^C_hatch ansi31 200 0 --- works fast and well! But the hatch is not associative!
Message 7 of 18
steven-g
No bug here, could be one on your machine, did you follow the prompts setting the scale and rotation etc. after setting the pattern name. And giving hpassoc the correct value as @pendean suggested.
Message 8 of 18
steven-g
Oops just spotted your using '_hatch' try this version '-hatch' in your macro it gives you much more control for the command line version
Message 9 of 18
pendean
Community Legend
Community Legend
Works absolutely fine here with your macro in LT2019 and LT2021 Boss, you've got something else going on. You can always include the HPASSOC setting in your macro to always confirm it is on to see if that helps.
>>>...Any text I type beside the hatch command breaks the accociation to boundary...<<<
Unless you think associative hatching is supposed to do something else perhaps? I have no idea what that statement even means, I can type TEXT and MTEXT all day long and hatch association is never affected.
Message 10 of 18
pendean
Community Legend
Community Legend
>>>...Oops just spotted your using '_hatch'...<<<
Makes no difference here.
Message 11 of 18
steven-g
Really, there are two very distinct sets of prompts between those two versions, at least on my machine
_hatch
-hatch
Message 12 of 18
pendean
Community Legend
Community Legend
That may be the solution for the OP. I used the OP's second macro (first post) in both LT2019 and LT2021 here as is, no changes, no issues.
Message 13 of 18
steven-g
Curiouser and curiouser, I just ran the OP's macro and it indeed fails to create an associative hatch no matter what the hpassoc setting (2019, 2020 and 2021) so if it works for you there must be some other variable difference. But yes the more extensive -hatch version will let you set associativity.
Message 14 of 18
pendean
Community Legend
Community Legend
LT2019.1.2 here in Win10Pro, nothing special otherwise.
LT2021 has no updates installed, same laptop.
Message 15 of 18
steven-g
Same macro
Message 16 of 18
So looks like the bug detected.
I have 2019LT at work and 2011 at home. Problem is noticed quite long time ago on both machines. I have sent tens requests to the Autodesk office, they only suggested to read the forum...
Sorry for the bad English lang, I normally speak other one 🙂
At the moment sitting home with the 2011, the versus "-hatch" makes app frozen for 2-3 minutes but I try. It seems that using -hatch I can't choose the hatch type cause it uses the last one.
Thank you very much for the help!
Message 17 of 18
steven-g
If it is working for @pendean then it is unlikely to be a bug, maybe some other obscure variable or setting, as for the  "-hatch" version try this
^C^C^C-hatch;p;ansi31;200;0;a;a;y;;s;\;;
you don't need to finish the macro by pressing enter at the keyboard the macro takes care of that for you (just select an object)
Message 18 of 18
GREAT! It works! Thank you! And no freezes,Asshatch solved.PNG very fast
