AutoCAD LT Forum
I have a standalone Autodesk AutoCAD LT 2016. I need to convert PDF files into DWG files.
5 REPLIES 5
harrison071004
217 Views, 5 Replies
I have a standalone Autodesk AutoCAD LT 2016. I need to convert PDF files into DWG files. Is there an add on I can buy ? What about an online site ?
Tags (1)
5 REPLIES 5
pendean
in reply to: harrison071004
No addons for LT. Sorry.
There are plenty of online services that claim to do this for you, help yourself https://www.google.com/search?q=pdf+to+dwg
hwalker
Why do you need to convert them?
PDFATTACH can insert a PDF into your drawing
Howard Walker
Left Handed and Proud
Hi @harrison071004
Thanks a lot for posting your question to the forums!   Have the solution suggestions by @hwalker & @pendean helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
harrison071004
in reply to: hwalker
We sometimes get only PDFs and I need to make small changes and add things in Autocad
hwalker
convert pdf to dwg online - Search (bing.com)
Gives quite a few suggestions.
Also if you have Adobe Illustrator that can convert PDFs to DWG format.
HOWEVER any program which says it will convert the PDF to a DWG format will only work well if the PDF is of vector format, if it's a raster pdf it won't work properly.
Howard Walker
Technology Administrators
