How to save a autoCAD 2016 file to 2007 with Proxy Graphics
I am trying to save a 2016 file into a 2007, but this comes up:
"This drawing contains custom objects that are not supported in previous versions. These objects cannot be saved to a previous version. You can do one of the following things.
Save this drawing to the current version;
Save this drawing as AutoCAD-only objects: to view AutoCAD objects in a previous version verify that the latest object enabler is installed.
Save this drawing to previous version with Proxy Graphics: if you open this drawing in a previous version you can view AEC objects as Proxy Objects but cannot edit them."
The question is:
How do I save it with Proxy Graphics?
or,
Any suggestion to save this file to 2007 version?
pendean
Community Legend
Community Legend
>>>...How do I save it with Proxy Graphics?...<<<
>>>...if you open this drawing in a previous version you can view AEC objects as Proxy Objects...<<<
What you want it's already doing: is there something else you are trying to do?
FWIW Use AECTOACAD (or -EXPORTTOAUTOCAD) commands to properly knock a file down to 2007dwg format.
