How to print multiple layouts
Message 1 of 12
How do I print multiple layouts at once in the same file, like a batch print so i dont have to individually print each layout?
Accepted solutions (3)
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
Highlight them all, right-click and go for it ... well, post back if you get stuck.
Message 3 of 12
Hi Dean,
How do you highlight them all?
Message 4 of 12
h_s_walker
Click on the first tab. Hold down the shift button. Click on the last tab.
Howard Walker
Left Handed and Proud
Message 5 of 12
Charles_Shade
Or CTRL to pick individually...
Message 6 of 12
It doesn't work!.
Is this a setting problem?
Polyrimutaka
AutoCAD LT 2012
Message 7 of 12
Charles_Shade
Click on the First Layout, Hold CTRL or Shift then click on the next Layout, either the end of the line or one by one.
If CTRL keep holding down the CTRL butto as you Select Layouts
Message 8 of 12
thanks a lot.. its working
Message 9 of 12
When using this method, the batch takes a long time to print or save to a PDF. Before I updated to 2018, I changed a setting that made the process much faster but it has reverted now and I don't remember where I went to make the change. Any ideas?
Thanks.
Message 10 of 12
OK, I remembered. You just have to deselect the box that says "publish in background". For some reason that option slows down the whole process.
Message 11 of 12
nicholas.stevens
have you tried to use the publish command?  you can remove the layouts you don't want to plot from the list
Message 12 of 12
Once selected, right click on a layout tab and select publish all.
Don't then go ctrl+p for print, you will still only get the currently viewed layout.
