How to export a dwg file without any attributes
Message 1 of 9
Hello, is it possible to export my .dwg file without the deeper informations of my symbols and all other attributes?
I just want to share the file like a stupid drawing.Smiley Wink
Many thanks for your help.
Replies (8)
Message 2 of 9
h_s_walker
Welcome to the Forums
DWF, PDF, JPG, PNG.
Or send them a paper copy of your drawing
Howard Walker
Left Handed and Proud
Message 3 of 9
Thanks for your fast reply. But i have to share it as a dwg file.
Message 4 of 9
h_s_walker
EXPLODE that will make your blocks lines and polylines and such
If your blocks have any attribute text you will need to reinput what the text says
PURGE will get rid of any unused items in  a drawing which will include blocks which are no longer present in the drawing
Howard Walker
Message 5 of 9
pendean
Community Legend
Community Legend
If you HAVE to share a DWG file, is your recipient OK with you sending them a totally destroyed file? You'd better ask if you are expecting payment for services in return for sharing, it's likely to get you in hot water.
Message 6 of 9
Emmsleys
Hello @Anonymous,
To add you could try the suggestion made by Jason.Piercey made in this similar thread.
You can also try using the following commands to help with what you're trying to accomplish.
EXPORTLAYOUT > then explode all blocks.
EXPLODE
AUDIT
Post back and tet me know if this helps. Smiley Happy
Sarah Emmsley
Technical Support Specialist
Message 7 of 9
Emmsleys
Hi @Anonymous,
Following up with your thread, were you able to get all the information that you needed?
Post back if you continue to have any questions.
Thanks.
Sarah Emmsley
Message 8 of 9
Hello Sarah,
i've found an solution which is working well. I export the file to .pdf and get it back with "import pdf" in ACAD 2017
it works fine.
Thanks for your help.
With all the best from good old Germany
Oliver
Message 9 of 9
steven-g
A bit late, but you could look at the wmfout and wmfin commands, the quality and results will depend on what is in your drawing, but it basically takes a picture, then you can bring it into another drawing as line work with text (and some of the text is also converted to lines), it also will need rescaling.
