How to edit text on multiple layouts
harveyXRS9Z
harveyXRS9Z
Is it possible to edit text on multiple layouts simultaneously?
I'm working on a drawing where there are identical text elements, e.g. the date, on each layout.  Can I change all of them at the same time.  I've looked on the Forums but not easily finding an answer to this.
I'm using AutoCAD LT 2022.
cadffm
>>"Is it possible to edit text on multiple layouts simultaneously?"
Yes
>>"identical text elements, e.g. the date, on each layout. Can I change all of them at the same time"
Yes
>>". I've looked on the Forums but not easily finding an answer to this."
Take a look to command: FIND
_
Doesn't matchs perfect, but in other cases:
and also command: FILTER
You can select all Text by using Filter and [apply to] ALL<enter><enter>
Change your Text value in properties palette now.
Sebastian
cadffm
2022? Upgrade to 2025 (or2024) and enter the world of LISP!
Out there are thousands helpful tools for you in www, some for text editing too.
Sebastian
harveyXRS9Z
Thanks for that, the FIND command is what I was needing and works well.
