Is there a command to remove multiple layout of the Paper Space, not just selecting one by one?
Thank you in advance!!
Solved by RSomppi. Go to Solution.
I need you help again.
It worked, after I asked to solution, but for some reason it stopped working.
I am selecting all layouts, but ones I want to deselect one of layouts, the function is selecting it instead of deselecting and deleting the layout I wanted to deselect.
Do you know some tip how make it work?
Not sure if 2019 has this menu, but you can go to your first layout, then open the hamburger menu on the left, and while holding shift click on the last layout, then right click > delete.
