How to change the BLOCK basepoint withouth moving them in model space
Message 1 of 31
As the title say, how can i change the basepoint parameter of a certain block withought moving them in its model postion.
Im working in this project and that has 1000 of block objects. I dont know what happen but im always setting my basepoint parameter on the center of the circles.
Rov
Replies (30)
Message 21 of 31
rbicigoR2VPK
Observer
Observer
Didnt realize it was LT - just did a search to find a solution and this string came up. Too bad for the LT users because the routine works great.
Message 22 of 31
Message 23 of 31
Johneng
Sorry to say third time is not the charm still no Lisp in LT. Read message 14 and Dean's post in message 15, then read message 17 and Deans' post in message 18.
Message 24 of 31
mehroimmi
thanks boss God bless u always. its really worked and good idea
Message 25 of 31
There is a LISP command that can do that.
http://www.lee-mac.com/changeblockinsertion.html
With the CBPR command, you select the block, select the new base point and it will change it on all the copies of that block, and they wont  move at all.
Message 26 of 31
steven-g
If you read this post you realise the post is about AutoCAD LT in the AutoCAD LT forum, there is no Lisp in Autocad LT
Message 27 of 31
RobDraw
That's amazing. So many people with the same LISP solution posting even after multiple reminders that this is the LT forum.
Rob
Message 28 of 31
thomas.mackay
Make a copy of the block. Explode it. Make a new block with a new name AND the correct orientation/origin. Add that in to the block you want to adjust. Delete the original elements. You now have a block with the correct orientation within a block with the wrong orientation. Exit the block. Select all the similar original blocks. Explode. The block within the original block remains. Rename this. Job done. No shifting blocks.
Message 29 of 31
NOURALDEEN
Dear All,
as I countered the same problem, I tried a LISP from LEE MAC, and it works perfectly, I changed Blocks base point with out changing the block position, no dynamic parameters were lost, you can find the lisp at :
regards
Message 30 of 31
steven-g
This Forum is for LT users, so a Lisp solution won't work.
Message 31 of 31
sbaines
How nice for all those unfortunate souls stuck on LT to finally be able to research solutions for the plethora of common problems in the full knowledge they'll now be able to utilise LISP routines; they being often the only viable/workable/economic solution. This long-awaited inclusion of LISP functionality within LT (from 2024 onwards) has not come before time.
