HOW to add the Z axis and enter 3d mode autocad lt (2015)
lara_chemaliVJ923
lara_chemaliVJ923
Community Visitor
Community Visitor
Hi!
I cannot see the z axis(using autocad lt-2015)
pendean
Community Legend
Community Legend
see the Z-axis? Please explain.
Also ensure your UCSICON command is turned on so you can see whether your UCS is rotated on not, about the only time you'll see "z axis".
lara_chemaliVJ923
Community Visitor
Community Visitor
Hi! Thanks for the help.
I checked my UCS as mentionned and still doesn't change.
Here is a picture of the viewer
mworshamFX7TJ
LT is pretty much 2D only. You can open a 3d model but you can't make a 3d object.  Similarly, you can switch to a front view but can't 3d orbit around an object, might want to check out fusion or full blown AutoCAD if you are planning on creating or manipulating a 3D object.  The only plane you can sketch on is the xy, you can get tricky and move this plane up and down, but for the most part that is useless and will just cause headaches.
pendean
Community Legend
Community Legend
@lara_chemaliVJ923 Your screenshot shows you're still in 2D viewing mode, are you not familiar with UCS command and/or 3Dview options in your menu?
LT2015's HELP file is a good place for you to explore the topic indepth
https://help.autodesk.com/view/ACDLT/2015/ENU/?guid=GUID-BAF31027-04B3-45BC-832B-074865CE8749
