AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
How do you measure (in mm) the length of an arc?
5 REPLIES 5
37507 Views, 5 Replies
I have completed a drawing on AutoCAD LT 2005 and cannot fathom out how to take a measurement of the arc - can anyone help?
I also need to segment the object into 5 equal sections ie a wall - how can I do this?
5 REPLIES 5
DIMARC is a feature of LT2006 and higher:
http://s-www.autodeskpress.com/resources/olcs/acad2006/oct05/topic.aspx
Search around here for a macro for lower versions of LT that kind-of-worked
for many of us before that, if upgrading is not an option.
For any Pro-Users reading this, check our the tip on that page for
AiDimFlipArrow.
Dean Saadallah
http://LTisACAD.blogspot.com
Length of Curve=2 x (pi) x Radius x Delta/360
Can you turn that arc into a polyline and then List it?
Heck I just noticed that highlighting the arc and looking at its properties tells me the arc length, without turning it into a polyline...
...also, look into the Divide command for adding evenly spaced points to a line or arc...
”Boost
