How do I prevent my AutoCAD window from getting smaller
Every once and awhile when I'm switching back to AutoCAD LT 2018. My window goes smaller instead of staying the same size as I left it. The image is what I'm talking about.
This may not be a AutoCAD thing but a Windows.
OS: Windows 10 Pro
Victoria.Studley
Hi @Anonymous,
The issue you're describing sounds like the one in the following article. Could you try the solution outlined here and let us know if it helps?
AutoCAD will not restore maximized from the taskbar
If one or more of these posts helped answer your question, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Victoria.Studley
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
