how can i e-mail a dwg to some one with out auto cad
robSHT8J
robSHT8J
Community Visitor
Community Visitor
I need to change my Dwg. to a Pdf. file so some one with out Auto cad can look at it
pendean
Community Legend
Community Legend
PLOT command in AutoCAD, select a PDF driver, and remember where you dropped the PDF file, then send them the PDF file.
Or ask them to install the free DWG viewer then send them your DWG file http://www.autodesk.com/products/dwg/viewers
ara_neresesian
Hi
After sending pdf file tell your frend in autocad it can be impoted by xref or insert , its depending to rhe cad ver .
In 2018 ver the PDF file which you importing can be converted to autocad objects
Be careful if you want to keep your file as only gay which have that file , it can be converte very easy
Good luck
Emmsleys
Hi @robSHT8J
Welcome to the AutoCAD LT forum board.
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Sarah Emmsley
Technical Support Specialist
Emmsleys
