AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Hatching
5 REPLIES 5
606 Views, 5 Replies
Hatching
I'm trying to get the hatch command to function like I would like but am having trouble.  When I hatch an area all is well until I erase the hatch.  Then it erases the hatch and also the surrounding lines.  If I change the boundary retain option, it draws a border around the hatch and that border covers up my line type below.
How do I set up hatch so that it doesn't draw a line around the hatched area and/or does not remove my original lines when the hatch is erased.  I don't want the hatch command to create a visible boundary covering up my drawn lines and I don't want my drawn lines to be erased when I erase the hatch.  I'm using LT2012.  What are the settings to achieve this?
5 REPLIES 5
drjohn
Tools > Options > Selection tab > Uncheck Associative hatch option.
Hover over it to see the tool tip about it ... "If this option is selected the boudary objects are also selected when you select the hatch".
HTH
DJ
in reply to: drjohn
Thanks Dr John.  I figured it out and was coming back to post my solution but you beat me to it.  At the office, the machines are set up with assoc hatching turned on and those machines do not have the problem I'm having.  I compared the system variables using setvar (?) and can't find a difference in the office machine vs my home setup.
Thanks again.
pendean
Turn off 'associative' hatching: there is a check-box for that on the HATCH command pop-up or you can explore HPASSOC variable in HELP and turn it off.
when i hatching an object the boundary line of that object erased...please someone help me out...
pendean
Not enough information.
Technology Administrators
