Hatch to current layer
Message 1 of 14
I'm trying to place the hatch into the current layer. "Current Layer" is selected in the hatch window, but it proceeds to place the hatch onto Layer 0.
Replies (13)
Message 2 of 14
pendean
Community Legend
Community Legend
What is your HPLAYER variable set to? Look up usage in HELP and set it the way you need.
Message 3 of 14
My HPLAYER value is set at 0, but I don't know what that means.
Message 4 of 14
pendean
Community Legend
Community Legend
@Anonymous wrote:
... it proceeds to place the hatch onto Layer 0.
0 means... "layer 0"
Did you get a chance to look up the HPLAYER variable in HELP? it explains how to set to to default to your current layer. Do so now, its a good learning moment.
Message 5 of 14
HELP doesn't solve. Thanks anyway.
Message 6 of 14
When I enter the command "HPLAYER" this is what I see:
HPLAYER Enter new value for HPLAYER, or . for use current <"0">:
What do I enter to solve my issue?
Message 7 of 14
cadffm
Start HPLAYER and push the magic button.
[F1]
Sebastian
Message 8 of 14
F1 brings up the Autocad HELP. I've done this. This is what I see.
HPLAYER (System Variable)
Specifies a default layer for new hatches and files.
Type: String
Saved in: Drawing
Initial value: use current
Values other than *.* (use current) value override the current layer (CLAYER).
How do I apply this info to address the issue?
Message 9 of 14
pendean
Community Legend
Community Legend
Let's break down the commandline response:
"Enter new value for HPLAYER" is asking you to put in a new value: so what should you put in? Let's look at the second part o the sentence
", or . for use current" is offering up that you enter . (a period or a dot or whatever you want) to set it to use the "current" layer.
Lastly, it shows in quotes "0", this is where AutoCAd is showing you what you have set right now, namely the layer 0 (zero).
in HELP, when you look up HPLAYER command it expands the description in more detail and says:
"Values other than the "." (use current) value override the current layer (CLAYER Command)."
. means use current layer.
Hope that helps (no pun intended).
Message 10 of 14
At this point, the easiest thing to do is to go ahead and let Autocad place the hatch into whatever layer it wants and then go back and do a CHPROP to change the layer. I'm not a power user of Autocad so maybe I wasn't conveying my issue effectively.
Message 11 of 14
Okay. I get it now. Problem solved. Now it makes sense. I just needed to step back re-read the HELP info.
Message 12 of 14
ChrisPreece
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @pendean provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Chris Preece
Technical Support Specialist
Message 13 of 14
admin47
The solution provided works-but for heavens sake why did it take 12 emails to get a solution?
Comments like 'press the magic button' are not helpful. Just say what the answer is!!!!
Message 14 of 14
pendean
Community Legend
Community Legend
The first response was the answer, so you did not get it either?
As the OP said (and it may help you to do the same):
"...I just needed to step back re-read the HELP info...."
Good Luck.
