Hatch pattern scaling
haroldT2HCV
Message 1 of 9
haroldT2HCV
Hello
When using hatch patterns the scale is very large (1000, 2000 etc) to obatin a suitable scale
In the past scales have been considerably lass than this (10 - 100)
Tried to draw concrete hatch pattern and only achieved a solid hatch regardless of scale
This has happened previously on other hatch patterns
Your suggestions would be most appreciated
Harold
Accepted solutions (4)
Replies (8)
Message 2 of 9
steven-g
Which template are you using metric or imperial and what is the size of the area you are trying to hatch?
If you look at the hatch pattern file then for 'ar-conc' the pattern will produce gravel at about 1" or 25mm depending on your template and your drawing units. But AutoCAD does use 'units' so in imperial the gravel is 1 unit and in metric 25 units (at a scale of 1).
So what is the approximate width of the area you are hatching and which template are you using?
Message 3 of 9
h_s_walker
Also are you using an annotative hatch? If so you need to make the scale (ringed in the image below) the same scale which you want your hatch to be
Howard Walker
Left Handed and Proud
Message 4 of 9
pendean
Community Legend
Community Legend
Post your DWG file, lets see what you did for ourselves, thanks.
Message 5 of 9
haroldT2HCV
Hi Steven
Thank you for your prompt reply
I am using metric and the size of the areas varies - 900 x 400mm; 3000 x 150mm...and so on
Since posting this query I hatched a larger size (4000 x 3000mm) which worked perfectly and then "matched properties" from the larger to the smaller areas and everything worked
It's a mystery as to why it did this in the first place but the outcome is fine and if it happens again then I'll just use the same method
Thank you for your time
Harold Stuetz
Message 6 of 9
haroldT2HCV
Hello hwalker
I'll give that a go.....
Many thanks
Harold Stuetz
Message 7 of 9
haroldT2HCV
Hi pendean
Here's the file...
Many thanks
Harold stuetz
Message 8 of 9
pendean
Community Legend
Community Legend
So you just lost track of scaling then in the first try, it got fixed (or reset) in the second attempt: you control all of that in HATCH command's SETTINGS option.
Message 9 of 9
haroldT2HCV
Hi Pendean
Sounds like we have solved the problem
Many thanks
Harold
