AutoCAD LT Forum
Hatch - Island detect doesn't work correctly when used with object select.
5 REPLIES 5
4846 Views, 5 Replies
I am trying to write a script that will automatically hatch several drawings. The drawings contain an area in which there are several objects that need to be hatched. For each drawing the objects vary in location within the one area.
I figured I would set up my script to encompass the area with the object select hatch technique. This works fine if the objects in the area have no Islands. However when an object within the "object select hatch area" contains Islands it shades the whole object ignoring the Island or if it does recognize an island it will create an individual hatch for it.
However when I use the pick internal point method the hatch comes out as expected for the object with the Islands in it.
Very stumped any help would be appreciated!
5 REPLIES 5
pendean
pendean
Community Legend
Community Legend
Post the content of your script file, let's have a look.
Here is the script I was trying to work with;
-Layer COlor 1 DIPS1
COlor 110 Dips110
COlor 120 Dips120
Color 140 Dips140
Color 150 Dips150
COlor 2 DIPS2
COlor 3 DIPS3
COlor 4 DIPS4
COlor 40 Dips40
COlor 5 DIPS5
COlor 6 DIPS6
COlor 60 Dips60
COlor 7 DIPS7
COlor 70 Dips70
SET DIPS5
"Please extend all contours to blue outer circle & Make a Few breaks in outer blue Circle outside of contours"
_circle 3.43,4.34 3.6
Zoom E
-Layer OFF "*" y
ON DIPS1
SET DIPS1
ON DIPS5
_-boundary A B E I Y O P
5.3,6.9
-Layer OFF DIPS5
Erase 6.0,7.7 0,7.3
-Hatch P S A H Y I Y
S 7,8 0,0
-Layer OFF "*" y
ON DIPS1
SET DIPS1
ON DIPS5
-BO A B E I Y O P
5.3,6.9
-Layer OFF DIPS5
Erase 6.0,7.7 0,7.3
S 7,8 0,0
-Layer OFF "*" y
ON Dips110
SET Dips110
ON DIPS5
-BO A B E I Y O P
5.3,6.9
-Layer OFF DIPS5
Erase 6.0,7.7 0,7.3
S 7,8 0,0
"END OF SCRIPT!"
Since then I have created a work around where I basically create 2 fake outer boundaries, hatche the outer area with Island detect wich hatches the areas I want, and use the trim option to slim the hatch down since it wont create separate hatch objects for some reason. Works most of the time.
COlor 110 Dips110
COlor 120 Dips120
Color 140 Dips140
Color 150 Dips150
COlor 2 DIPS2
COlor 3 DIPS3
COlor 4 DIPS4
COlor 40 Dips40
COlor 5 DIPS5
COlor 6 DIPS6
COlor 60 Dips60
COlor 7 DIPS7
COlor 70 Dips70
SET DIPS5
Zoom E
-Layer OFF "*" y
ON DIPS1
SET DIPS1
ON DIPS5
5.3,6.9
-Layer OFF DIPS5
Erase 6.0,7.7 0,7.3
S 7,8 0,0
-Layer OFF "*" y
ON DIPS1
SET DIPS1
ON DIPS5
-BO A B E I Y O P
5.3,6.9
-Layer OFF DIPS5
Erase 6.0,7.7 0,7.3
S 7,8 0,0
-Layer OFF "*" y
ON Dips110
SET Dips110
ON DIPS5
-BO A B E I Y O P
5.3,6.9
-Layer OFF DIPS5
Erase 6.0,7.7 0,7.3
S 7,8 0,0
"END OF SCRIPT!"
Charles_Shade
Charles_Shade
HPSEPARATE need to be 1 in the drawing perhaps?
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
pendean
pendean
Community Legend
Community Legend
-HATCH command > Advanced > Island Detection, you don't seem to address it in your script: would that cure the problem?
in reply to: pendean
Actually in the script the hatch command options are as fallows;
Properties > Solid
Advanced > separate Hatches > Yes
                  > Island detection > Yes
Thank you both for your ideas but unfortunately that isn't the problem. I believe it is a bug in the hatch software. A better solution is maybe to drop down my number of lines that create the Island boundaries but I'm not sure if that will even work.
I have also attached the dxf file I start with and the final drawing file I'm after to give you a better idea. I basically need to fill the dxf file contours Automatically then insert it into a drawing. I have no control over how the dxf comes out by the way. I wish they had closed or at least intersected their lines.
Properties > Solid
Technology Administrators
