Guidelines not appearing anymore
ernestDG3ZU
ernestDG3ZU
The green lines that appear when you are drawing, moving objects, etc no longer appear.
Did I maybe press a hotkey that I am not aware of?
How do I get them back without un/re-installing the software?
Thanks in advance.
ernestDG3ZU
I think I found it.  It is a check box called Object Snap TRacking.
steven-g
You can also turn it on/off using the F11 key or there is one of the icons across the bottom of your window that toggles it on/off. You possibly pressed one of those!
