I have some dynamic blocks set up with fields that automatically change a dimension text depending on where you stretch the part to.
When I grab more than one layout tab, and select Publish Selected Layouts, go in and select DWG to PDF and set all the right settings.... I then plot the file to one file containing all the sheets. When it plots, everything looks ok except when it comes to the section views (see p2 of 13) [view says PANEL 30 - AS VIEWED FROM BOTTOM OF FORM]. The text that should be a field with a dimension line says ##########.
Is there a variable that controls this? I thought it might be FIELDDISPLAY so I changed that to 0, but it doesnt help,.
Dan Middleton
AutoCAD user since 1993
AutoCAD LT 2023
AutoCAD LT 2023
