Hi, my name is Stewart. I have AutoCAD LT 2016 installed on my laptop with Windows 10.. I cannot get the function keys from 1-12 to work or function in AutoCAD. There must be a way to assign the keys away from window functions while in AutoCAD, however I have not been able to find the solution. Please can someone help?
Solved by pendean. Go to Solution.
For your issue you may refer to this link https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Keyboa...
Or try to look at this thread with similar issue https://forums.autodesk.com/t5/autocad-forum/function-keys/td-p/3246662
Hope this will help your issue.
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
