I have Mleaders with text: 3/8" Thermal Break.
I want to replace it with the 3/4" Thermal Break.
unfortunatly Find And Replace can not detect the text. I tried changing the settings in the find and replace dialoge box but it does not help.
Solved by pendean. Go to Solution.
Thanks Dean
It is stacked fraction. unstacking them would be as easy as to re-enter the correct text than to run find command after unstack.
Hi there, did you ever find a solution to use find and replace dialog box with diagonal fractions? I have a lot MTEXT with HSS5x5X3/8 (the fraction is auto stacked to a diagonal fraction) to a 4 1/2X3 1/2X 3/8.
Would you please let me know whether you were able to find a way to solve this problem.
