File Tab keeps defaulting to the last Tab open when I close a File Tab
Braird_Engineers
Braird_Engineers
Can anyone please explain whether it is possible to change the hierarchy of the file tabs so they are recognised left to right as (1st, 2nd, 3rd etc) instead of right to left (3rd, 2nd, 1st)?
There must be a way to change this as I am constantly facing this issue everyday while working on drawings.
Thank you.
pendean
Community Legend
Community Legend
Just click and drag to sort them anyway you want: try it now.
Braird_Engineers
This is not considered a solution and does not fix the problem, I want the hierarchy to from left to right, instead of right to left.
Whenver I drag the tabs and close Tab (2) it automatically goes to the last tab instead of Tab (3).
pendean
Community Legend
Community Legend
Thanks for the additional info about your desires. TABs are sorted by order of file opening, nothin else, you have no other choices in AutoCADLT.
Perhaps you need to turn of FILETABS altogether and implement/start using SSM (SheetSet Manager) exclusively with your projects? You have to do the work/setup up front but it solves your need for organizing.
csmithF28SL
Something I've noticed when selecting multiple files at once (FYI: my file folders are set to "Details" view, and sort alpha-numeric default Windows settings):
If I select a sequence of files in the order they appear in the window--for instance, top to bottom--the application always opens the LAST file in the sequence first, appearing in the 1st position (left), followed by the subsequent files in their respective A-Z order.
However, if I select the same sequence of files in reverse order (bottom to top), the application will open them in their respective A-Z order.
I don't know why it does this--it ALWAYS has, and it's annoying. I can't say I've had your exact experience, but I'm not surprised to hear it. None of the "experts" in Autodesk community have been able to solve the trivial discrepancy I've been having since it appeared with the 2021 release. I even included screenshots a described in detail what happens. I'm convinced they're either stumped or they're still trying to duplicate the issue locally.
Something that has helped me navigate through the file tabs quicker than mouse clicking is the CTRL+TAB shortcut. This will select the file tab to the right of whatever tab you are currently viewing; SHIFT+CTRL+TAB to select the tab to the left. And this function does "round robin", meaning that if you are working in display tab on the far right, CTRL+TAB will return you to the tab on the far left, whether that be the Start tab or your first file. And likewise, S+C+T will return you to the last tab on the right in the "anti-clockwise" direction. Hope this helps a bit.
