Fatal Error
Fatal Error
darshan_m_athnur
Fatal Error
darshan_m_athnur
AutoCAD LT showing Fatal error as Unhandled Access Violation Reading 0x15ab1b Exception at ED45784h.
How to fix this issue?
h_s_walker
Do you have a load of images on your drawing?
What memory is installed in your machine?
Howard Walker
Left Handed and Proud
darshan_m_athnur
Sir, Please go through the file.
pendean
Community Legend
Community Legend
Your posted DWG file is damaged and will not open here either: try these many ways to fix it https://sourcecad.com/how-to-repair-autocad-drawing-file-and-fix-its-errors/#:~:text=opening%20at%20....
and
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/AutoCAD-File-Corru...
If those do not help, then search for backup and autosave files to recover
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Understanding-Auto...
If you did not ever get a chance to backup your files manually over the time you've been using it.
h_s_walker
I had the same problem as Dean. It would lock up LT2016 every time I opened it and in Trueview it gave a fatal exception error and crash
Howard Walker
darshan_m_athnur
Then how to resolve this issue, sir?
h_s_walker
@darshan_m_athnur Try the fixes Dean suggested in his post
Howard Walker
