Fatal Error when using particular drawing - AutoCAD LT 2015
- Mute
- Permalink
- Report
Hello!
I've been experiencing some problems with a particular set of drawings that I've been using for the past couple weeks. The drawing is not particularly complicated; 6 viewports in paperspace, 2 arrays with embedded hatches along with a couple simple drawings on the side in Model Space. Basically when i open this drawing I attempt to add/draw/delete anything, and eventually (after maybe 2 min of tampering) the cursor stops repsonding and crashes giving me a Fatal Error (Violation reading 0xfffffffffffff at exception e428d2dch).
I don't have a problem with any of my other drawings, and the main difference between them seems to be the amount of viewports. In my other drawings I typically have at most 2 and run into trouble only with the drawings with the 6 viewports or more.
I've double checked that my system is capable of running LT 2015 and has ample abilities to get the job done but will crash everytime this drawing is open.
I've also ran Audit along with _purge to no avail. It should be noted that I've had this problem before, used Audit and purge, and that did the trick. But that solution no longer seems to do it.
I've been struggling with this all day, and any advice or insights into what might be going on would be very appreciated! Thanks.
