Fatal Error: Unhandled e06d7363h Exception at F84A388h
formwerkzitadmin
formwerkzitadmin
when use an Existing excel file or browse for a new one i received This Fatal Error: Unhandled e06d7363h Exception at F84A388h Ver 2019 Autocad LT.
john.vellek has embedded your image(s) for clarity
markcalloway
Hi @formwerkzitadmin
A few suggestions for you here:
  • Use the AUDIT command to fix any faults in your cad drawing.
  • Copy the content of the excel document and past it into a new excel spreadsheet and save, try loading from the new excel file.
  • copy the excel document and dwg locally (to your desktop) and see if that helps.
  • if you have access to another computer with AutoCAD copy both files to it and test on another computer.
A few suggestions there to get you going, if your still having issues let us know.
Mark
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
john.vellek
Hi @formwerkzitadmin,
I see that you are visiting as a new member to the AutoCAD LT forum. Welcome to the Autodesk Community!
Can you please tell me the WINVER of your OS?  Please also tell me your exact version of AutoCAD LT by typing ABOUT at the command line.  What is your graphics card make and model?
Is this happening in all your files and if so, when did this behavior begin?
John Vellek
