FATAL ERROR: Unhandled e06d7363h Exception at 85707788h
Can I get some help?
This Error always came out.
Even i turn-off the Hardware Accelerator it still a problem.
VinodBalasubramanian
Autodesk Support
Autodesk Support
Hi There,
Good day.
When do you get this fatal error. Is it while opening a particular drawing or while launching AutoCAD LT. Can you provide us your current LT version and the OS you have installed in.
Appreciate your inputs.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Hi sir thank you for your time.
It appears at a random time while my engineer is using this file.
pendean
Community Legend
Community Legend
There is no fix for "random": see if the user can narrow down the problem say during the use of a specific command, command sequence, or if they have certain other apps open (or even if their phone is plugged into the PC for example).
Emmsleys
Hi @ lemuel., welcome to the forums!
Random fatal issues are difficult to troubleshoot.
Are you able to capture the workflow prior to the fatal error message?
Can you provide more information?
Sarah Emmsley
Technical Support Specialist
