Just installed MS Office on my Win7 laptop and when I run ACAD LT 2012, the program crashes within 5 mins with this fatal error. Can anyone help?
Solved by Emmsleys. Go to Solution.
Hi @lonewuff Welcome to Autodesk Community!
Could you please try the solution in this link: Error: "Unhandled e0434352h Exception at fde1940dh" when launching AutoCAD ? Hope it helps.
Have you applied all service packs and hotfixes to AutoCAD LT 2012?
Post back with any updates or if you have any other questions.
I uninstalled Microsoft .NET Framework & (3) Microsoft Visual C++ Runtime Libraries. Cannot uninstall ACAD now which is the next step. Should I reinstall both again?
If you try these steps are you still unable to uninstall the application?
Perform a clean uninstall of an Autodesk product that is crashing when started or displaying fatal or unrecoverable errors.
Locaton of Trusted Storage files
Vista or Windows 7 /8 /10 |
Windows XP |
Mac |
Clean out your TEMP files:
* Note: This information can also be accessed through this AKN article: Perform a Clean Uninstall
