I don't see much for resolutions to this error, but we have a similar error using Autocad and Civil 3D 2014 but when running through RDP.
Our exact errror is "FATAL ERROR: Unhandled Access Violation Reading 0x0040 Exception at ed982b50h" in our case. I have found by using RDP that AutoCAD 2014 and Civil 3D 2014 do not like hardware acceleration being on. If it is on we get this fatal error crash on some computers. Testing while sitting at the computer the software launches up fine. You can force the application to startup with Hardware Acceleration off by modifying the shortcut to launch the program. Put at the end of the target location " /NOHARDWARE" with leading space and without quotes.
Example AutoCAD 2014
Just copy the shortcut, then modify propertys to be "C:\Program Files\Autodesk\AutoCAD 2014\acad.exe" /product ACAD /language "en-US" /p /NOHARDWARE
Hope that helps someone else looking up this error.
Here is a link that talks about switches http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Startup...
